10 Users Online (8 Members):
Forums >> Revit Building >> Tips & Tricks >> door frame off-set
I am looking for a door family the shows the door sitting in the wall in the correct location? revit door sit centered in the wall whether its a stud wall or a wall that has a stone veneer or brick veneer with a stud. I would like the door to sit in its proper location of the stud portion of the compound wall (stone-stud) and I am not sure how to do that or if anyone has done that already
Your definition of proper location and mine may be different ... especially depending on frame type. And do you mean the door or the frame?
I modified our door families building them around a frame offset parameter.
my apologies, I am refering to the entire assembly. if I have a compound wall (stone-ply-stud-gyp) I would like the door at a minimum to sit within the stud portion of that compound wall. right now the doors seem to center themselves on the entire wall assembly. I believe the door and door frame should sit under the stud framing and not the stone portion of the wall.
You have to re-build the family as I did. Typically, I like to start with a reference plane well off the wall with a setback dimension (like 12") off the face of the wall. Then I add all the model components around this ref plane and end by setting the setback parameter to something more logical,
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
Demo Door Leaf not Frame |
Thu, Nov 15, 2012 at 9:31:09 AM
Door Frame |
Tue, Sep 28, 2004 at 5:58:51 PM
Best practice for scheduling door frame types when the frame is a curtain wall |
Mon, Mar 23, 2015 at 10:49:57 AM
Door schedule/frame width |
Wed, Mar 3, 2010 at 12:04:47 PM
