Forums >> Revit Systems >> Technical Support >> Cannot see my floor levels
Tue, Mar 10, 2015 at 12:17:36 PM | Cannot see my floor levels
tomphilips
Hi everyone
i was modeling in revit and created some floor levels. the levels themselves are sill there but i cannot see the level lines in the elevation views.
does anyone know if there is a way i can bring them back without creating new levels
thanks
Tue, Mar 10, 2015 at 12:23:45 PM | Cannot see my floor levels
HKicsak
Check the extents of your elevation view- change your crop region until you can see the level line, then drag the line to where you need it
Tue, Mar 10, 2015 at 12:27:17 PM | Cannot see my floor levels
tomphilips
I have checked and they are no where to be found isnt there a setting where i can highlight them to see where they have gone?
Tue, Mar 10, 2015 at 12:42:26 PM | Cannot see my floor levels
Please pay attention to what HiKicsak wrote.   If the datum does not intersect a view’s plane (or does not intersect the plane in the correct way), then it will not be visible in that view.
Use the elevation view (UNCROP IT!) and make sure the view depth will intersect your levels.  You may have to go to a perpindicular view.
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
Problem w display of floor patterns over diff. levels
Sat, Mar 19, 2005 at 2:05:24 AM
Spot levels on external floor family
Fri, Aug 17, 2007 at 2:44:13 AM
Single Floor with multiple levels
Tue, May 14, 2013 at 10:24:40 AM
Moving Floor Levels Independently
Thu, Feb 25, 2010 at 1:37:17 PM
Page generation time: 0.5309
