12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> template (.rte) or project (.rvt) files
63 Posts No Rating |
I want to save a template for residential work but I am confused between saving the file as a template or a projec file. What is the difference?????
thanks for any help
the .rvt is the project file or .dwg in autocad
the .rte is the template file or .dwt in autocad
best regards,
coreed,aia
yes I think I get the defenition of the two files but technically what is the difference? If I was to save my residential template as a .rvt file, how would that differ to the file I would create saving it as a .rte file?
when you create a new file starting from a template(.rte) file, the new file is given a default name and populated with the info from the template. Any changes made to this new file will not affect the info contained in the template.
if you were to use the project file (.rvt) as a template file it would always open with the same name
and unless the first thing that you did was do a save as and give the file a new name any changes that you make would also be changing your template. which defeats the purpose of having a template file.
most of the differences between project files and template files are operational
hope this helps
best regards,
coreed, aia
Revit Template File from Project file .rvt to .rte |
Sun, Apr 28, 2013 at 1:35:39 AM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides |
Tue, Feb 10, 2009 at 2:19:03 PM
RTE vs RVT |
Thu, Sep 26, 2019 at 9:21:04 PM
Cannot get the Mechanical-Default_Metric.rte template to load |
Sat, Jun 9, 2012 at 2:30:21 AM
OLD project with NEW template |
Fri, May 30, 2008 at 8:27:49 PM
