Forums >> Revit Building >> Technical Support >> Long line in project
Mon, Mar 9, 2015 at 3:18:09 AM | Long line in project
Wilder87
I've build a model in exisisting construction, demolished some of it and then rebuild a new area. After that i made ventilation on one floor and i dont know at what point, but now i got a lone line from the middle og my building stretching way out. I cant remove or delete it, i cant even select it. I have tryed to select the whole building but nothing seems to help. The line is also only shown in new construction phases.
I'm using Revit 2014
Anyone seen this problem before?
Mon, Mar 9, 2015 at 5:35:48 AM | Long line in project
HKicsak
Does this line print? If it doesn't print then does it matter?
I've had something like this happen before, but with linked models. I forget that I have 'select links' turned off and then it takes a little while for me to figure out it's an element in a linked model.
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop?
Tue, Mar 10, 2015 at 2:51:14 AM | Long line in project
Wilder87
Yes it does print, and select link is enabled.
Tue, Mar 10, 2015 at 6:41:40 AM | Long line in project
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have anything linked into your project?  If so is it part of the link? Can you do a save-as and purge your project and ease everything but the line and upload it here so we can take a look
Tue, Mar 10, 2015 at 7:23:27 AM | Long line in project
Did you audit the file?   That should be your first step.
Then I would use a bubble sort to try and identify what may be causing this.  Delete half the elements and see if it goes away.  If it doesn't, then delete half of what's left....continue until you isolate the problem to a group that you can then work with using the same process.
Tue, Mar 10, 2015 at 10:01:03 AM | Long line in project
Wilder87
Thanks for the fast answers.
I have tryed toaudit the file and purged all the unused, didnt help.
I havnt linked anything into my project yet, but now i made a seperate file, deleted everything and then purged it.
The file is linked to this post.
Thanks
Tue, Mar 10, 2015 at 11:09:34 AM | Long line in project
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There's nothing attached, make sure your file size is small enough, there is a 2Mb limit
Wed, Mar 11, 2015 at 3:03:05 AM | Long line in project
Wilder87
I'll tri again, i can see now that the line is somehow depending on the 04 1 sal level
But still cant figure how to remove it without deleting the entire level. A little progress atleast.
Thanks.
Wed, Mar 11, 2015 at 7:39:20 AM | Long line in project
It seems to be a supply duct.  There was one element in the project but when I deleted that, the line still did not go away.   You can turn that category on/off but the file must be corrupted.
Thu, Mar 12, 2015 at 3:08:54 AM | Long line in project
Wilder87
Okay thank you alot.
How long does it take for Revit to relinguish a project
Fri, Mar 27, 2009 at 9:34:03 AM
How long should it take????
Mon, Feb 2, 2009 at 9:42:01 AM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
How to make the dash line scale right in project ?
Fri, Jul 9, 2010 at 7:38:32 AM
How long does it take...............
Sun, Jun 25, 2006 at 5:25:03 PM
Page generation time: 2.9689
