Forums >> Revit Systems >> Technical Support >> Electrical circuit prefix separator
Sun, Mar 8, 2015 at 11:29:34 AM | Electrical circuit prefix separator
donks38
After much messing around with the settings for circuit numbering I have found that I can show the numbering as the panel name and the phase and outgoing way by choosing by "phase" in the propoerties drop down but for some reason this seems to be the only setting that will not accept the circuit prefix separator???
Instead I get the panel name then the phase (L1, L2 or L3) but the outgoing way is then straight after without any separation so the circuit reads for example...DB1-L11 as oposed to DB-L1-1. This is confusing as it could look like this was way 11 and not way 1 on phase L1. There must be a way to get the separator to work as it works fine on all of the other drop down options such as "panel name" or Prefix etc, just not with "by phase".
Circuit Homerun
Tue, May 5, 2009 at 1:40:57 PM
Electrical Systems
Tue, Feb 5, 2013 at 12:20:37 PM
Downloaded Manufacturer Light Family - can't circuit
Fri, May 16, 2014 at 2:43:26 PM
Electrical Circuit Spares - 20A
Mon, Aug 20, 2012 at 9:58:48 AM
Split Circuit Receptical Circuiting with Branch Duplex Recepticals
Tue, Mar 27, 2012 at 3:07:09 PM
Page generation time: 0.4504
