Forums >> Revit Building >> Technical Support >> Waqll Sweeps- Revit 2015
Sat, Mar 7, 2015 at 9:19:57 PM | Waqll Sweeps- Revit 2015
5dtgeorgiton4
I hae duplicated a wall type to add base sweeps- however I have pocket doors in some of these walls- the sweeps do not break at the pocket door- so I wanted to try to manually place them in a 3D view.
   The problem is- the only sweep that is loaded into my "Properties" is the cornice. When I go to families in my Project Browser_ I find the sweep I want to use- but I can't seem to get it permanantly entered into my Properties field.
  What am I not doing? Revit tells me to click on the "place sweep" button- in modify/sweeps ribbon- but I can't get that ribbon to open.
  I appreciate any help with this- thanks!
Sun, Mar 8, 2015 at 10:57:36 AM | 5dtgeorgiton4
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting 5dtgeorgiton4 from 2015-03-07 21:19:57
Are you adding a sweep to a wall in its type properties? Make sure 'cuttable' is unchecked - see picture.
To use a profile as a wall sweep, in the profile family set 'profile usage' to generic or wall sweep.
Also, see help menu. Hope it helps Smile
Sun, Mar 8, 2015 at 2:04:04 PM | Waqll Sweeps- Revit 2015
5dtgeorgiton4
Thank you for your input. It turns out those weren't my problems. I had to go into "Edit Properties" for the "cornice" (the only
 Profile that appeared in my Properties Browser) - Duplicate it - rename it to the base I wanted-  & Pick that base profile from the "edit Properties" then it was loaded into my Browser so I could use it. All the help I found only described how to place the profile - they didn't go through how you had to load the profile into the browser.
  I do appreciate your response though  Your second suggestion is one I have written down for future troubleshooting issues.
Mon, Mar 9, 2015 at 8:43:44 AM | Waqll Sweeps- Revit 2015
Although your process worked, it was not what you really want to do.  pijpiwo had you on the right track.  When you create a profile using the family editor, you need to set it's usage.  Then it will be available as a new wall sweep type.
Mon, Mar 9, 2015 at 10:02:03 AM | Waqll Sweeps- Revit 2015
5dtgeorgiton4
  I will try that- I didn't think about that setting as this is an "out of the box" sweep, not one that I created. Thanks
Opening a 2015 drawing in Revit 2014
Tue, Jul 29, 2014 at 9:11:58 AM
AutoCAD 2015 Lines Scramble when imported into Revit 2015
Tue, Jul 7, 2015 at 3:23:06 PM
Revit 2015 Ultimate / Standard compatibility?
Wed, Oct 1, 2014 at 6:10:21 PM
Wall Joining Issue Revit 2015
Wed, Nov 4, 2015 at 7:56:51 AM
11
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
11
Page generation time: 7.7569
