Forums >> Revit Building >> Technical Support >> furnature missing on plan
Fri, Mar 6, 2015 at 1:09:48 PM | furnature missing on plan
Kathe33
2013 revit
placed tables looled fine then i come back today and there gone. I can see them in section but cant unhide in plans.not all furnature is missing just a few tables and chairs. any ideas ?
Fri, Mar 6, 2015 at 1:15:34 PM | furnature missing on plan
So many possibilities....
  1. What category is this missing 'furniture' in?  Many users build families in the wrong category.   What ever category may not be on in that view's VG.
  2. Were the items hidden in view?  Hit the lightbulb.
  3. We the items placed in a different phase?  Check the property of the item in a view where you can see them.
  4. Could the item be in a different workset?
  5. Could the item be in a design option?
  6. Could the items be above the cut plane of your plan view?
Fri, Mar 6, 2015 at 1:46:37 PM | furnature missing on plan
KCren
I had the same problem before. Turns out that the family is set so that it is not visible based on detail setttings (coarse, medium, fine).
At the bottom left hand corner you should see a checkerboard or a white box beside the cube. Click on it to change the detail settings.
Also fix your family by clicking on the parts that you want visible in your model. Go to visibility/graphic in the properties tab and check the detail level coarse/medium, etc. according to your needs.
Fri, Mar 6, 2015 at 3:01:55 PM | furnature missing on plan
Kathe33
Sorry tried it all, great sugestions nothing worked. really has me stumped.
Mon, Mar 9, 2015 at 7:46:14 AM | furnature missing on plan
The family may be only 3D and turned off in plans.  Look at the family visibility settings.
Floor Pattern Overlaps Furnature
Tue, Nov 30, 2010 at 5:44:57 AM
Structural plan is missing from View tab> plan views
Mon, Apr 29, 2013 at 8:04:26 AM
Looking furnature for shop floor?
Tue, Nov 17, 2009 at 1:09:25 PM
Missing Floor Plan from Browser
Mon, Nov 5, 2012 at 6:31:47 PM
Walls, Windows Furniture ect missing on level2 plan
Sun, Aug 16, 2009 at 5:42:55 AM
Page generation time: 0.4113
