Forums >> Revit Building >> Technical Support >> Balcony railing issues - Revit 2014
Fri, Mar 6, 2015 at 12:13:17 PM | Balcony railing issues - Revit 2014
motodesign
Yes, I've serached before posting Smile
Please see attached.  For some reason my posts aren't filling in the area circled, but are fine everywhere else.
I have them set to 4" apart and to spread to fit.
Also, is it possible to have the 45 deg. corner "clean up"
All help is appreciated!
Thanks!
Fri, Mar 6, 2015 at 12:25:01 PM | Balcony railing issues - Revit 2014
Square posts and rails will never join correctly at non 90 degree corners.  How can they when 2" Horizontal rail is larger than 2" on the diagonal then the 2" post?
You need to let the rails turn the corner  without a corner post or your post has to be larger than the rails.
Edited on: Fri, Mar 6, 2015 at 12:25:54 PM
Fri, Mar 13, 2015 at 11:36:41 AM | Balcony railing issues - Revit 2014
motodesign
any idea as to why the post aren't filling in the area I have circled?
and how would I have the rail turn the corner without the posts?
Edited on: Fri, Mar 13, 2015 at 11:44:55 AM
Fri, Mar 13, 2015 at 11:56:11 AM | Balcony railing issues - Revit 2014
No image with circle.
If you don't want corner posts, then turn them off in your railing definition.  See first image... Of course, then you may have to better define where your posts will be maybe like the second image.
Or ... maybe you should consider a bigger post - maybe even a round one?
Remember, you can use multiple railings to help control this.
Edited on: Fri, Mar 13, 2015 at 11:57:10 AM
Fri, Mar 13, 2015 at 12:19:14 PM | Balcony railing issues - Revit 2014
motodesign
The image is in the first post.
Fri, Mar 13, 2015 at 7:55:49 PM | motodesign
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting motodesign from 2015-03-13 11:36:41
Can you upload your railing, so we can troubleshoot?
Tue, Mar 17, 2015 at 4:25:57 PM | Balcony railing issues - Revit 2014
motodesign
I have attached the railing.
Tue, Mar 17, 2015 at 9:50:51 PM | Balcony railing issues - Revit 2014
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Delete all the balusters but one. That’s all you need, if all of them are the same.
Wed, Mar 18, 2015 at 8:10:29 PM | Balcony railing issues - Revit 2014
motodesign
ahh, so easy!  thank you,
another question.  is it possible to offset the posts so that they are 1" or so from the corner of the top rail, but still in line?
I tried the different offset options for corner post but that didn;t seem to work.
Fri, Mar 20, 2015 at 9:16:26 PM | Balcony railing issues - Revit 2014
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Probably it is not possible to create this detail with a single rail, but you can use a combination of multiple separate rails to achieve more complicated design. WW mentioned this in post #4. Enclosed is a quick example.
You can also try to play with the component railings with the handrails, supports, etc., where you can tab into the different rail parts, unpin them and manipulate as you wish ( to the certain degree of course).
Railing Connections
Tue, Jul 22, 2014 at 12:54:44 PM
Weird shadows created by pipe railings
Tue, Apr 11, 2006 at 8:14:34 PM
Creating your own custom railing? [ 1 2 ]
Mon, Jul 12, 2010 at 5:58:27 PM
15
Simple Balcony Railing - help!
Tue, Jul 10, 2012 at 12:24:44 AM
Level 2 (Upstairs) and Balcony floor
Thu, Feb 11, 2016 at 4:03:26 PM
Page generation time: 1.4217
