Forums >> General Discussion >> Revit Project Management >> import dwg surfaces into Revit
Thu, Mar 5, 2015 at 12:02:05 PM | import dwg surfaces into Revit
niemants
I have read a lot about it, but I can't really find what I want.The idea is: I have got some shapes from an architect to build a facade, a curtain wall for a house. The surfaces are all triangles in different directions. I would like to import these surfaces (dwg) into my Revit-file and then use them to build a curtainwall on them.
I can get my dwg-file imported, I can clean it with the visibility and layers. But I cannot use this surfaces. They are just objects in my Revitfile. If I extrude them, It becomes a projection on my floorlevel.
I hope somebody can help me,
Thanks
Thu, Mar 5, 2015 at 1:15:02 PM | import dwg surfaces into Revit
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Got a picture?
Are you able to recreate the form in Dynamo or in Revit itself?  Otherwise, I've never got CAD to work as a surface host for anything in Revit.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Fri, Mar 6, 2015 at 1:59:58 AM | import dwg surfaces into Revit
niemants
Hi,
Here is the picture of a part of it that I'm using as a test.
I haven't been able to recreate it in Revit 100% correctly because I can't get to snap the points of the imported dwg-file. It is just sitting there as a 3D image. I can't really use it.
Fri, Mar 6, 2015 at 1:56:09 PM | import dwg surfaces into Revit
KCren
Try Adaptive components? Create an adaptive component family on Revit.
I'm not to familiar with this part of Revit but I'm sure there are tutorials out there that can help you.
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
import dwg to revit but cant underlay
Sun, Apr 26, 2009 at 5:24:18 AM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
Exporting views for DWG
Tue, May 16, 2006 at 4:58:32 PM
dwg import bring to front
Fri, Jun 27, 2008 at 9:46:56 AM
Page generation time: 1.8195
