Forums >> Revit Building >> Technical Support >> "Level above" to show as hidden lines
Fri, Mar 17, 2006 at 9:24:57 PM | "Level above" to show as hidden lines
undertow
3 Stars: 2 Votes
So, how do you make, say a floor on the level above, show up on this level as hidden line? Underlay option won't allow a change in linetype Is the only answer linework? Thanks. UT
Sat, Mar 18, 2006 at 6:15:59 PM | RE: "Level above" to show as hidden lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Typically to do this i overlay the level on the sheet, set it to wireframe, override the linetype for the elements I want to show and turn off all unwanted elements. This is the most automated way, as using the linework tool on the underlay often requires updating manually when new elements are introduced. HTH.
Hidden line Help!!! Please!
Thu, Sep 20, 2007 at 7:04:30 AM
"Double" lines in view range beyond
Fri, May 17, 2019 at 12:34:14 PM
Displaying hidden lines in component families Revit 2010
Tue, Oct 6, 2009 at 7:21:47 AM
How to show glass as a "colour" in Hidden Line View
Tue, Jan 19, 2016 at 12:16:43 PM
Show Hidden Lines - Structural Foundations
Thu, Jan 13, 2011 at 10:37:01 AM
Page generation time: 3.4876
