Forums >> Revit Building >> Technical Support >> Custom Running Bond Brick Pattern
Thu, Feb 26, 2015 at 10:47:41 AM | Custom Running Bond Brick Pattern
bopps
Hi, I'm using Revit 2014 and want to make a custom brick pattern (model lines). I want to have a running bond using 18"x48" blocks - I've managed to make an 18"x36" .pat file but I'm not figuring out how to make a non 1:2 pattern. Seems pretty basic yet I'm new to making patterns. Any help would be greatly appreciated! Thanks.
This is what I have for the 36" even though I want a 48" width.
;%UNITS=INCH
;%VERSION=3.0
*Running Bond 18x36,  18 x 36 panels running bond
;%TYPE=MODEL,
0,             0,             0,             0,             18
90,            0,             0,             18,             18,             18,             -18
Thu, Feb 26, 2015 at 12:31:57 PM | Custom Running Bond Brick Pattern
Here is a 1/3 running bond - use that to help you figure this out.
*Brick Norman 1/3 RB, Brick: Norman - 1/3 running bond
;%TYPE=MODEL
0,0.0000,0.3750,0,5.3334
90,0.0000,0.3750,0,12.0000,2.6667,-2.6667
0,3.8711,3.0417,0,5.3334
90,3.8711,3.0417,0,12.0000,2.6667,-2.6667
Edited on: Thu, Feb 26, 2015 at 12:37:58 PM
Thu, Feb 26, 2015 at 12:35:06 PM | Custom Running Bond Brick Pattern
Or maybe this is easier to follow
*12x24 1/4 running bond
;%TYPE=MODEL
0,    0,0,    0,24
90,    0,0,    0,24,    12,-12
0,    6,12,    0,24
90,    6,12,    0,24,    12,-12
Edited on: Thu, Feb 26, 2015 at 12:36:18 PM
Fri, Aug 26, 2016 at 1:51:25 PM | Custom Running Bond Brick Pattern
sharx23
COULD YOU PLEASE EXPLAIN FOR WHICH BRICK IS THE CODE (1/3 STAGGERED)
Fri, Aug 26, 2016 at 2:38:25 PM | Custom Running Bond Brick Pattern
I believe that was for a standard norman : 3-5/8" x 2-1/4" x 11-5/8"
stretcher bond with mortar joint - custom
Mon, May 6, 2013 at 3:10:08 AM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
Help with brick hatch
Mon, Oct 27, 2008 at 5:39:36 PM
11
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Curtain Wall runnning bond pattern
Fri, Nov 4, 2011 at 11:34:18 PM
Page generation time: 0.2432
