Forums >> Revit Building >> Technical Support >> materail surface patterns
Fri, Mar 17, 2006 at 8:16:31 AM | materail surface patterns
bobz
We are using material surface patterns on several exterior wall conditions. But when revising the material pattern under setting/material/appearance/surface pattern, some walls change and some do not. Has anyone experienced the same problem?
Sat, Mar 18, 2006 at 10:11:24 PM | RE: materail surface patterns
FlyinHigh
1 Stars: 1 Votes
This has happened to me, but I figured out that I was overlooking a small detail, the exterior wall face was facing the interior of the house. So you may want to check that this has not happened.
Fri, Aug 24, 2007 at 9:49:07 AM | materail surface patterns
jmqrsq
5 Stars: 3 Votes
not sure if anyone will see this and respond but did you figure out what the problem was for sure? i am using 2008 and I have a brick pattern i am updating and it is changing in some spots but not others. brick material is the same and my walls are rightside out. any suggestions?!?!? thanks
Fri, Jun 13, 2008 at 8:06:11 AM | materail surface patterns
cashmoter
did you find a solution to this?  I have a Terracotta wall I want to change the size of the pattern in a shaded view and can't find a way to do it.
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
surface patterns and rendering
Sun, Jun 27, 2004 at 7:37:47 AM
Page generation time: 0.2759
