Forums >> Revit Building >> Technical Support >> Remove Wall Sweep Types
Fri, Feb 20, 2015 at 11:22:30 AM | Remove Wall Sweep Types
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Ok maybe its because its Friday but I cannot figure this out!  I have a wall sweep type called Wall Sweep - EIFS Crown 1.  It is in my template file and I want to delete it out because it is garbage but for the life of me I cannot figure out where to do this from.  I attached images of the properties if it helps.
Fri, Feb 20, 2015 at 12:08:25 PM | Remove Wall Sweep Types
When you start a project, there are several system level items that are defaulted in Revit just to give you something to start with.  You can never delete these fundamental elements but you can rename them and redefine them.  This may be that original type.
So you can edit this one to what you want to keep and delete the other types.
Edited on: Fri, Feb 20, 2015 at 1:18:48 PM
Fri, Feb 20, 2015 at 1:33:22 PM | Remove Wall Sweep Types
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Good idea to just rename it to use with something else. not sure how I didn't think of that.. still going to blame it on Friday brain.
And I had to go into Purge to get rid of the types that I made myself.  Thanks!
Edited on: Fri, Feb 20, 2015 at 1:39:30 PM
How to remove a Wall Sweep
Thu, Jan 6, 2011 at 5:23:23 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Sweep Types
Thu, Aug 4, 2005 at 5:22:19 AM
Wall Sweep Missing at Infill
Tue, Mar 6, 2012 at 2:06:39 PM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Page generation time: 6.6468
