Forums >> Revit Building >> Technical Support >> MISSING GRID LINE IN TWO FLOOR PLANS ONLY
Fri, Feb 20, 2015 at 9:54:53 AM | MISSING GRID LINE IN TWO FLOOR PLANS ONLY
KYLIEBRAITHWAITE
Hi,
I have numbered grid lines in my project but on two floor plans (B1 + B2) the grid line no. 16 is missing. It can be seen in all other plans, elevations and sections.
I have tried 'visibility graphics' and 'reveal hidden items'. But no luck!
Any other ideas?
Fri, Feb 20, 2015 at 10:06:05 AM | MISSING GRID LINE IN TWO FLOOR PLANS ONLY
Are these floors in the middle? - I bet not.   Grids have extends and if they don't intersect the view (either in plan or in elevation), they will not show.  You will have to correct that.
Fri, Feb 20, 2015 at 10:31:21 AM | MISSING GRID LINE IN TWO FLOOR PLANS ONLY
KYLIEBRAITHWAITE
YOU ARE RIGHT, Q16 IS MISSING ON THE BASEMENT LEVELS.
I SELECTED THE Q16 GRID (FROM AN UPPER LEVEL) THEN I CLICKED 'PROPAGATE EXTENTS' AND SELECTED THE VIEWS I WANT THE GRID LINES TO BE VISIBLE IN.
Q16 IS STILL MISSING?>
Fri, Feb 20, 2015 at 10:45:11 AM | MISSING GRID LINE IN TWO FLOOR PLANS ONLY
If this is a lateral problem, find a view where it does show and drag the end (3D) over into the area where it should be.  If it is a verticle problem, use a section or elevation view and drag it there. We are talking 3D here - not 2D ends.
You can use scope boxes too but that is too confusing at first.  This Help section may help you:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-4E36EDA0-2F4E-4619-B568-AC758E8D9770
Mon, Feb 23, 2015 at 3:24:53 AM | MISSING GRID LINE IN TWO FLOOR PLANS ONLY
KYLIEBRAITHWAITE
thank you WWHUB!
THAT WORKED. I WENT INTO AN ELEVATION AND DRAGGED THE Q16 GRID LINE DOWN TO THE LOWER LEVELS.
THANK YOU
Column Grid line missing when printing
Mon, Nov 23, 2009 at 11:20:50 AM
Grid Bubble Control in Different Views
Tue, Jul 10, 2012 at 7:22:19 PM
Missing Grid Lines
Wed, Jun 20, 2007 at 3:23:21 PM
Grid lines moving together in different floor plans
Mon, Sep 20, 2010 at 9:10:52 PM
Missing Grid Lines ...again
Fri, Mar 28, 2008 at 10:39:23 AM
Page generation time: 0.6669
