Forums >> Revit Building >> Technical Support >> Mullion behind Glass Question
Tue, Feb 17, 2015 at 5:33:47 PM | Mullion behind Glass Question
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I'm trying to model a Curtain Wall that has slats behind the glass. I'm hoping I can model the slats as mullions so that I can control them accordingly in lieu of curtain panels where the would be included. I modeled these elements using a profile that does not penetrate the center front/back reference plane so it doesn't trim the curtain panel. For the most part this works, but the mullion still divides the curtain panel. I don't want these edges to appear in any of my views, and I don't want to have to manage lineweights for the dozens of edges that would result. Does anyone have any suggestions for managing this? Thanks.
(Version: 2014)
Wed, Feb 18, 2015 at 7:48:53 AM | Mullion behind Glass Question
Use two curtain walls in the same place.  One has only these items but no glass and no verticals.
Tue, Mar 3, 2015 at 2:59:15 PM | Mullion behind Glass Question
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I was afraid of that. Gets a little messy with the vertical mullions wanting to be the supports for both the glass and the slats. But then again that is the design and the only alternative I guess is modelling them as a curtain panels. Thanks Mr. 'Hub!
Curtain Wall - Glass and Mullion Detail
Tue, Oct 2, 2007 at 4:19:30 PM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Corner Mullions not extending glass to meet
Wed, Aug 2, 2017 at 1:57:54 PM
Custom Mullion Profile
Thu, Apr 23, 2009 at 3:47:59 PM
Mullion offset from exterior glazing
Sun, Feb 14, 2010 at 10:05:21 AM
Page generation time: 1.8663
