Forums >> General Discussion >> Revit Project Management >> Colour Scheme (Areas) disappears when a plan region is added
Sun, Feb 15, 2015 at 7:14:06 PM | Colour Scheme (Areas) disappears when a plan region is added
Kristian13
Hi all,
Not sure what is happening here, but a colleauge has her plans all set up with areas, colour schemes applied etc.
It all works well, but then she adds a plan region so that some doors display correctly, and hey presto, the colour schemes disappear!
Once we change the bottom range and view depth to match the level (ground) it re appears, but i have never seen a rlan region cause the colour scheme to disappear liek this.
Any thoughts on why?
We are using Revit 2015.
Cheers,
Kristian
Sun, Apr 19, 2015 at 11:27:47 AM | Colour Scheme (Areas) disappears when a plan region is added
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Change the floor finish of your floor object to none. If it has a pattern, the pattern will over-ride colour fills
Area plan and colour scheme issue: 2008
Thu, Nov 29, 2007 at 10:39:39 PM
Room & Area Colour Scheme
Mon, Nov 24, 2008 at 10:37:48 PM
Areas Plan
Tue, May 14, 2013 at 12:02:12 PM
Elevation Colour Scheme
Wed, Aug 6, 2014 at 3:55:15 AM
Room Areas and Colour Schemes
Tue, Oct 21, 2008 at 3:51:29 AM
Page generation time: 0.9776
