Forums >> Revit Building >> Technical Support >> Offset floor same level
Thu, Feb 12, 2015 at 12:38:51 PM | Offset floor same level
palowe
Hi,
i have a 2' floor offset whitin the same level. For input purposes i created two different level names, so when i place instances I don't have to offset every single of them for that area.
The problem now is for schedules. I am trying to do a zoning analysis/gross area schedule and I don't want to see them separate. Any idea of how to merge them...?
Thanks,
Thu, Feb 12, 2015 at 1:20:55 PM | Offset floor same level
Did you do an area plan?   The areas can all be defined as the same level.   Your rooms to can be placed from one plan.  For volumns, the floors will cop the room from the bottom just like the ceiling crops the top of the rooms.
Thu, Feb 12, 2015 at 3:50:34 PM | Offset floor same level
palowe
YES thanks works. Thanks
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
Site Elevation to Floor Level Problem
Wed, Jun 27, 2012 at 11:42:30 AM
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
Visibility of 2nd Floor in REVIT 2011
Sun, Nov 21, 2010 at 8:51:10 PM
level offset and rcp
Wed, Mar 12, 2008 at 6:00:20 PM
Page generation time: 0.4641
