Forums >> Revit Structure >> Technical Support >> Phases Filter
Tue, Feb 10, 2015 at 10:10:29 AM | Phases Filter
cketros
Hi all,
If the building have all the phases, start with shell (building) then phase 1-5 for all rooms and partitions.
how can I filter out when all completed, only need to show phase 1-5 as new but building remain as previous.
Thank you.
Tue, Feb 10, 2015 at 10:22:58 AM | Phases Filter
You can not do what you want with the normal phase filters because you only have previous and new and that steps through all phases.   If you place each phase on seperate worksets, you can create filters by workset to achieve what you want.
Tue, Feb 10, 2015 at 2:38:10 PM | Phases Filter
cketros
Thank you WWHub, it works perfectly with workset along with phasing.
Thank you again,
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
Phasing: creating 3 phases, filter out middle
Thu, Jan 22, 2015 at 9:02:29 AM
Filtering by Phases - Revit MEP 2015
Thu, Jul 2, 2015 at 9:06:08 AM
Can't filter "Phase Created" in MTO for linked Revit files?
Mon, May 12, 2014 at 7:01:45 AM
Phases
Fri, Jul 12, 2013 at 11:22:58 PM
Page generation time: 0.0761
