Forums >> Revit Building >> Technical Support >> Revit 2015 Crashes when attemptiing to save to central
Tue, Feb 10, 2015 at 5:57:36 AM | Revit 2015 Crashes when attemptiing to save to central
MaxNomad
Good day all,
We're using Revit 2015. There are no problems working with the model until attempting to save to the central file. It then throws an error, crashes, and exits the program.
I've tried installing all the Autodesk updates and making sure that the OS is up to date. Attached is a sample from the journal leading up to the crash. Any input would be greatly appreciated. Thanks in advance!
Tue, Feb 17, 2015 at 5:12:05 PM | Revit 2015 Crashes when attemptiing to save to central
raja15
Not sure if this helps but our office is having the same problem when we go to print.
Same thing, we have installed all the updates, it's just when we go to File>Print the entire window freezes and crashes on us.
I'm now wondering if this is happening to other offices as well ?
Wed, Feb 18, 2015 at 7:51:38 AM | Revit 2015 Crashes when attemptiing to save to central
If both of you have the latest updates and drivers installed, then you need to contact your reseller.
We are not seeing these complaints here so it is something unique to you and your systems.
Thu, Feb 26, 2015 at 11:04:16 AM | Revit 2015 Crashes when attemptiing to save to central
kamakazi34
I'm having these problems with saving locally but not synchronizing to central.
Running fully updated Revit 2015.
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
save central
Wed, Apr 8, 2009 at 9:02:46 AM
Central Model File locations - clouds Revit Arch 2015
Wed, Dec 6, 2017 at 10:10:53 AM
Error..wouldn't let me save to Central...help needed
Wed, Feb 28, 2007 at 9:48:56 AM
Can't share central file
Mon, Nov 23, 2009 at 4:07:18 PM
Page generation time: 1.6704
