13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Alinged Dimensions
is there a way to find the lenght of one side of the roof? or a way to do an alinged dimension
There a few ways I can think of doing this.
If the roof edge is cut perpendicular (not plumb cut) to the roof face, you could string a dimension from the roof edge to a point at the peak of the roof (press tab until a single dot appears at the ridge).
If that doesn't work, try drawing reference lines or planes perpendicular to the face of the roof and copy the lines/planes to the peak and string dimensions between the two lines/planes.
Select the dimension tool
Tab through the elements until you get a POINT
Click on the point
Do the same with another point and you have yourself a dimension aligned between two points.
ill have to try that, since what we have to do is build a fom model of one of our projects
EQ Display in dimensions Revit 2009 |
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details) |
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions |
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions |
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared |
Wed, Apr 25, 2012 at 10:37:51 AM
