Forums >> Revit Systems >> Technical Support >> Revit Local File, Central Could Not Be Found
Mon, Feb 9, 2015 at 2:29:29 PM | Revit Local File, Central Could Not Be Found
koolair
4.5 Stars: 2 Votes
Hi guys, I am looking after a couple new Revit users and he stumbled onto a problem.
This is probably an oldie, but I can't remember running into this problem for a number of years.
His local file is so old it is not able to link with Central.
So I told him to create a new local. I told him he should create new locals every week or so at least. Just so these problems don't happen.
So he clicked File Open, and clicked the central file once. He looked to see if the "Create New Local" box was checked, but it was actually greyed out. Can someone help me out here?
Thanks!
Mon, Feb 9, 2015 at 2:36:20 PM | Revit Local File, Central Could Not Be Found
Open local detached if he has no central then the create new central is automatic.
If he has a central, do a save as then the create new central will be under options.
Central & Local Files
Mon, Dec 21, 2009 at 8:42:07 AM
Error - Local File Resides in Central File Location
Fri, Apr 9, 2010 at 8:34:55 AM
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:26 AM
Central Model File locations - clouds Revit Arch 2015
Wed, Dec 6, 2017 at 10:10:53 AM
Central/Local File Synchronizing Issue
Sun, Jun 23, 2013 at 2:33:20 PM
Page generation time: 1.6944
