24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Having a small roof problem Revit 2015
3 Posts No Rating |
Is there a way to add a gable along a straight roofline? In other words, I want to simulate a gable without moving any walls to create the offsets you would normally have with a true gable. I haven't been able to find a way to make it work on Revit. I can make it happen when I frame the structure, but I don't know how to make it work in the program.
I used the "roof by extrusion" to create the look, but there are several problems:
I can't join the roofs
I cant flush the front of the gable with the existing hip
Untitled.pngEdited on: Sat, Feb 7, 2015 at 5:11:39 PM
Edited on: Sat, Feb 7, 2015 at 5:13:03 PM
Edited on: Sat, Feb 7, 2015 at 5:20:17 PM
3 Posts No Rating |
Use slope arrows.
EDIT: Link added.
Edited on: Sat, Feb 7, 2015 at 6:18:25 PM
3 Posts No Rating |
Thanks for the help! I figured it was probably a very easy fix that I was blind to.
3 Posts No Rating |
I got it to work, but how do you adjust the slope? I need to join to another roof and I am having trouble getting the pitch to match.
Thanks
See the picture and this link.
3 Posts No Rating |
Well that was easy too. Thanks so much for the help!
how to cut a hip roof in revit. how to attach a small roof to a big roof |
Fri, Feb 11, 2011 at 1:16:54 PM
Revit 2015 Install Error |
Tue, May 20, 2014 at 9:24:55 AM
material patterns rotate when exporting to a DWF revit 2015 |
Thu, Jan 22, 2015 at 12:41:59 PM
why only segement of my roof cornice can't jointed well at the corner |
Mon, Feb 14, 2011 at 1:43:28 AM
Roof Problem |
Sat, Mar 9, 2013 at 10:01:25 PM
13
