Forums >> Community >> Newbies >> Sloped Wall Direction
Thu, Feb 5, 2015 at 2:13:46 PM | Sloped Wall Direction
coastalclimbing
I created an inplace mass and the created a wall by face. Is there an easy way to switch the exterior face of the sloped wall? Spacebar is not working and I don't see an arrow above the wall like on normal vertical walls.
Thu, Feb 5, 2015 at 2:29:41 PM | Sloped Wall Direction
Is your wall defined incorrectly ...exterior vs interior?
Thu, Feb 5, 2015 at 2:35:20 PM | Sloped Wall Direction
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to place your wall on the correct side of the mass, there is no quick toggle to switch it.
Tue, Feb 17, 2015 at 9:52:32 AM | Sloped Wall Direction
coastalclimbing
How do you define the wall? I have attempted to draw/create wall by face on either side of the sloped wall and they always end up in the same direction.
Tue, Feb 17, 2015 at 10:20:09 AM | Sloped Wall Direction
It is not how you place the wall.   Two things:
  1. When you do wall by face, look at the options bar, the location line setting.  The wall will be placed on your mass according to this setting.  So if you want the exterior face of your wall at the mass face an the remainder of the wall burried in the mass, chose the exterior face setting.
  2. Under wall properties, the wall is defined   from the exterior side at the top down to the interior face.  Always define your walls correctly.
A Sloped Curve Wall
Thu, Aug 7, 2008 at 4:17:27 PM
Door in sloped wall, need help building frame
Mon, Jun 23, 2014 at 2:25:11 PM
SLOPED FLAT ROOF
Sat, May 9, 2009 at 9:09:38 AM
Can Revit draw a vertically sloped axi line?
Mon, Jul 16, 2012 at 7:22:26 AM
Sloped terrain and sloped foundation wall
Thu, Sep 3, 2009 at 1:57:36 PM
Page generation time: 1.2157
