Forums >> Community >> Newbies >> Creating PIPEWORK
Wed, Feb 4, 2015 at 7:40:16 AM | Creating PIPEWORK
fifthtexas
Any good tips when creating pipework, i am placing pipework in ceiling voids and want to create a standard of having them all at a set distance apart, whats bets method?
Wed, Feb 4, 2015 at 8:09:55 AM | Creating PIPEWORK
andygleach
4.5 Stars: 37 Votes
Hi pal, have you tried using the Parallel pipe under Plumbing & piping? Thats if your using Revit MEP.
You would have to create a pipe run first and then simply use the Parallel pipe. with this you can provide veritcal and horizontal pipes and there spacings.
Sounds the best way for me.
Hope this helps
Pipework Types Visibility on/off
Thu, Jul 3, 2008 at 9:02:46 AM
pipework showing differently
Thu, Jan 29, 2015 at 8:09:36 AM
Probelm Selecting pipework
Thu, Nov 8, 2007 at 7:13:19 PM
Indicating Generic Pipework and service equipment on survey building model
Wed, Oct 1, 2014 at 8:19:33 AM
Switch off Pipe systems in Revit MEP
Mon, Aug 17, 2015 at 8:33:14 AM
Page generation time: 0.3262
