Forums >> Community >> Newbies >> graphic problem
Tue, Feb 3, 2015 at 9:00:08 AM | graphic problem
PerferAutoCad
I have been adjusting line weights by element and category but when I print (using Bluebeam) the line become dashed.  The reason I am doing this is because I used a structural slab instead of a floor for the slab on grade and they are two different weights (it was my first job). I am using R15.
Tue, Feb 3, 2015 at 9:30:22 AM | graphic problem
You do not have to do what you are doing.   VG treats all floors the same.
Maybe you have a filter applied that changes this.
The only difference between Structural vs architectural is a simple switch in properties of the floor.  The view's discipline also affects what is shown in a view.
Wed, Feb 4, 2015 at 2:11:36 PM | graphic problem
PerferAutoCad
Changing the discipline to architectural or coordination remedies the problem, and so does clicking off hidden line in the properties window.  The question still is why is it doing this.  It makes no sense.
Wed, Feb 4, 2015 at 2:39:10 PM | graphic problem
The hidden line setting may be from your ini settings:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-9D26B850-026A-4734-BB76-997154ADE5F2
Revit Architecture 2013 - Wall graphic problem
Wed, Mar 20, 2013 at 5:34:35 AM
Phase Graphic Overrides
Wed, Jul 10, 2019 at 4:01:45 PM
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
sheet graphic override
Thu, Dec 16, 2010 at 11:03:16 AM
Crop Region and Graphic Column Schedule
Thu, Jan 2, 2014 at 6:13:52 PM
Page generation time: 0.5552
