Forums >> Revit Building >> Technical Support >> editing elevations & sections
Wed, Mar 15, 2006 at 3:56:17 PM | editing elevations & sections
leeroy
I have been using Revit now for about 2 months & have got a reasonably good grasp on most of it but I am still unable to edit my elevations & sections. Can somebody tell me how to perform functions such as erase after an elevation or section has been inserted into a sheet (or before insertion - it doesnt matter) I need to be able to 'pretty' up these views as there is always elements I need to alter & it is too cumbersome most of the time to fiddle around with the model. I would have thought that you could change the sheet to 2d, thus enabling you to work on the sheet as you would in Autocad. Can any one help me please?? cheers
Wed, Mar 15, 2006 at 4:19:16 PM | RE: editing elevations & sections
arccodex1
3 Stars: 1 Votes
Elevations and Sections ARE the model. To pretty up elevations and sections you can apply the linework (LW) tool, Drafting Detail Lines, Detail Components, and Filled regions on top of the model. The Drafting tools are view specific. When used they don't show up in other views unless you copy and paste them to other views. Post edited on 2006-03-15 16:20:08
Wed, Mar 15, 2006 at 4:54:39 PM | RE: editing elevations & sections
leeroy
thanls so much for the speedy reply. I guess my main question is how dow you erase unwanted lines from elevations & sections. do i need to create a filled region of some kind over the top of the line to be removed? The lines im trying to remove are those scrappy little ground lines where the model meets the terrain. thank you
Wed, Mar 15, 2006 at 5:34:49 PM | RE: editing elevations & sections
arccodex1
3 Stars: 1 Votes
To erase unwanted lines use the LW tool, select "invisible lines", and pick the lines you want to make invisible.
Wed, Mar 15, 2006 at 7:04:26 PM | RE: editing elevations & sections
leeroy
thanks very much for that
Wed, Mar 15, 2006 at 10:26:07 PM | RE: editing elevations & sections
leeroy
arccodex1... thanks for your help to date... just one more question - I hope - why is it not possible to make invisible the lines in the middle of a composite wall ? ( ie brick veneer wall) I can only make invisible the outside lines & the same applies for different layers of a floor.
Thu, Mar 16, 2006 at 10:49:00 AM | RE: editing elevations & sections
arccodex1
3 Stars: 1 Votes
You'll have to goto the walls properties... Edit/New... Edit structure if you want to alter the layers and patterns in a given wall. Or just change your Detail Level to coarse in the View Properties. Post edited on 2006-03-16 10:50:10
Thu, Mar 16, 2006 at 4:45:49 PM | RE: editing elevations & sections
leeroy
thanks again
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:48 AM
Casework Elevations and Sections
Wed, Jan 16, 2013 at 3:42:09 PM
Using Filers on Elevations & Sections
Mon, Aug 19, 2013 at 9:41:35 AM
steel sections for download
Mon, Sep 17, 2012 at 11:56:10 PM
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
Page generation time: 0.9501
