Forums >> Revit Systems >> Technical Support >> Problems using IFC Files
Thu, Jan 29, 2015 at 6:54:23 AM | Problems using IFC Files
mondrian1968
Hello!
Please excuse my ignorance but I am an Interior Designer who is fairly experienced in Revit. Having said this, I havent needed to work with IFC files before but I have just received a Revit model together with the IFC file from an Architect and need to use these files in order to produce a space plan, finishes and visuals etc.
The problem I have is that the model has no levels, 3d views etc. I have linked in the IFC file into the model and vice versa, but nothing appears workable. If somebody can offer me a procedure for creating a working model out of these files it will be very much appreciated.
Thanks!
Thu, Jan 29, 2015 at 9:24:57 AM | Problems using IFC Files
Thread Post Kudo! #2
Start by reading all the entrys in your HELP on IFC then the similar threads below and searching on the web.
IFC files
Wed, Oct 11, 2006 at 9:31:42 AM
Revit IFC export and NavisWorks 2009
Tue, Nov 18, 2008 at 11:15:34 AM
No Import - Maximum size of IFC imports?
Sun, Jul 10, 2016 at 6:56:30 AM
reading ifc files
Wed, Oct 27, 2010 at 5:00:27 AM
Using IFC files
Wed, May 19, 2010 at 8:59:41 AM
Page generation time: 0.3372
