10 Users Online (8 Members):
Forums >> Community >> Newbies >> OBJECT STYLE ISSUE
Hi,
The one major problem i have faced is controlling object style and line weights.
I have modelled my beams under "structural framing"
by default its cut lineweight was 2. but in object style i changed it to 5. but i cant see any change in my sections.
wierdest part is this- when i "edit in place" the cut lineweight changes to 5!
attached images of the problem.
Is your object assigned to any of the structural framing subcategories? If yes, you need to expand struc. framing category in the object style window and change that subcategory.
CHANGED ALL SUBCATEGORIES TO 5.. STILL THE SAME PROBLEM
It could have been overridden in view ‘by element’.
Select it -> right click -> override graphics in view -> by element -> hit ‘reset’
NOPE.. I HAVENT OVERRIDEN GRAPHICS
Hey Sud12,
Just wanting to check, have you got thin lines turned off?
Short cut is 'TL'
Also, try changing the projection lines to the '5' line weight.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
That means it is not overridden by category or filter either, right?
Edited on: Fri, Jan 30, 2015 at 7:53:33 AM
The easiest way to check for possible over-rides is to create a new view without a view template applied.
Are you sure this item is what you say it is?
Are your sure the item is being cut or is it possible it is in elevation beyond?
Detail Component Object Style? |
Fri, Apr 9, 2010 at 10:01:48 AM
Apply material to object style not working. |
Fri, Jun 15, 2012 at 7:33:23 AM
Object Style not showing unless object highlighted |
Thu, Jun 8, 2017 at 3:29:24 AM
Linked object style |
Thu, Apr 20, 2017 at 8:31:06 AM
Object Style / Visibility Graphics |
Thu, Aug 5, 2010 at 3:21:25 AM
