Forums >> General Discussion >> Revit Project Management >> Revit 2014 - Create a custom model pattern
Tue, Jan 27, 2015 at 7:25:57 PM | Revit 2014 - Create a custom model pattern
Kristian13
Hi all,
I am trying to create a custom model pattern which can be used on floors, etc.
Refer to screen shot for how i want it to look. Squares are 400mm by 400mm, with a 150 strip between, then the next row of squares are offset to align with the centre line of the square above.
I have tried editing the .pat file and reimporting it. While i can get the file into revit, i just cant get it to look like the screen shot.
Lines are going everywhere, except where i want them!
If anyone could help with creating a quick file for me, or pointing out the settings i need, it would be much appreciated.
Cheers,
K
Tue, Jan 27, 2015 at 10:33:00 PM | Revit 2014 - Create a custom model pattern
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Can you upload your pat file?
Wed, Jan 28, 2015 at 12:20:27 AM | Revit 2014 - Create a custom model pattern
Kristian13
Sorry, i lost my patience with it and deleted it!
If i get a chance, i will try and write a new one.
Wed, Jan 28, 2015 at 9:11:11 AM | Revit 2014 - Create a custom model pattern
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I asked for the file, because it's easier to modify existing rather than start from scratch, …anyway, enjoy.
;%UNITS=MM
*name
;%TYPE=MODEL
0,  0,0,  0,550
0,  0,400,  0,550
90,  0,0,  0,400,  400,-700
90, 200,550,  0,400,  400,-700
Edited on: Wed, Jan 28, 2015 at 10:15:06 AM
Wed, Jan 28, 2015 at 9:30:43 PM | Revit 2014 - Create a custom model pattern
Kristian13
Thank you pijpiwo for creating that file, however, it does not import. i am getting the "No model type patterns found" error message.
Attached is the exact file i am trying to import, with name added, as per your original coding.
Wed, Jan 28, 2015 at 10:19:31 PM | Revit 2014 - Create a custom model pattern
Kaily
a
Wed, Jan 28, 2015 at 10:25:46 PM | Revit 2014 - Create a custom model pattern
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Hmmm..., I'm not sure why it's not working for you, but try this pat file.
Edited on: Wed, Jan 28, 2015 at 10:27:17 PM
Sun, Feb 1, 2015 at 5:07:59 PM | Revit 2014 - Create a custom model pattern
Kristian13
That file worked a treat.
Thank you so much for your help. Much appreciated pijpiwo.
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 2:01:39 PM
Custom Model Pattern from AutoCAD DWG
Tue, Dec 31, 2013 at 12:39:00 AM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
create a custom fill pattern [ 1 2 ]
Mon, Jun 28, 2021 at 2:32:51 PM
29
Editing Model Patterns...
Mon, Jan 4, 2010 at 12:56:50 PM
Page generation time: 1.8449
