Forums >> Revit Building >> Technical Support >> All new elements inserted are dashed/hidden lines
Mon, Jan 26, 2015 at 6:54:46 PM | All new elements inserted are dashed/hidden lines
Raybo57
I'm guessing this is a setting i just haven't been able to figure out, and searching the web hasn't helped, so here goes:
I'm working on the stairs in a model started by someone else. Everything I put in new is showing up as a dashed line instead of a solid  line of solid. But it's not just the rails.  It's anything new i put in.  Can modify what's already been put in,and no issue.
I'm using Revit 2015.  Original model was done in Revit2015 LT.
Started another small project from scratch, and everything in that is fine.
I expect it's some simple setting, but I'll be darned if I can figure out which one.
Thanks in advance for any suggestions
Raybo
Tue, Jan 27, 2015 at 6:48:09 AM | All new elements inserted are dashed/hidden lines
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What do you mean everything?  Like all of your stair components or literally all families?
Tue, Jan 27, 2015 at 7:34:01 AM | All new elements inserted are dashed/hidden lines
Create a new plan and see what happens.   I expect it is VG settings, maybe set by a template.
Tue, Jan 27, 2015 at 8:03:48 AM | All new elements inserted are dashed/hidden lines
Raybo57
Everything.  Walls, columns, beams, stairs.  Everything "new" I'm adding is coming in with a dashed/hidden line type.
And it seems to be something just in this model.  I have a small kitchen layout I did from scratch, and to test things, put in a stair and structure and some other "stuff", and everything is fine.
I've checked the Object styles, and that looks correct.  Long time ACAD user, relatively new to REvit, but just can't figure out what's goin gon...
Tue, Jan 27, 2015 at 8:07:55 AM | All new elements inserted are dashed/hidden lines
Look at your view's properties.   What phase are you working in?
Tue, Jan 27, 2015 at 8:11:16 AM | All new elements inserted are dashed/hidden lines
Raybo57
@WWHub...
Already tried that.  First thing i tried, because had V/G issues with the "out of the box templates".  For plans, elevations, sections and 3D, too.
No joy...the "added" stuff still shows up as that linetype in every view...???
Tue, Jan 27, 2015 at 8:17:49 AM | All new elements inserted are dashed/hidden lines
Raybo57
Bingo...phases.
Changed the items to new construction from "Project Completeion" to "New Construction" and the styles changes.
Thanks...
Now, can you suggest where/how I need to go check to set that to the default for new items.  I don't knw oif i accidentally did it, or if was set before i startedworking on the model, but would be helpful not to have to change it for everything i'm going to be adding in.
Raybo
Tue, Jan 27, 2015 at 8:23:43 AM | All new elements inserted are dashed/hidden lines
The phase and phase filter are set by view.   If the view phase is set to existing then eveything you add while working in that view will be existing.   You can select any object though and change it's phase.
READ ABOUT PHASES IN YOUR HELP!   It is the best tool for newbies.
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:48 PM
show hidden lines dashed in 3d-view
Tue, Feb 14, 2006 at 5:29:29 PM
Dashed lines in plan from window above
Mon, Oct 11, 2010 at 3:28:04 PM
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:48 AM
Page generation time: 0.6130
