Forums >> Revit Building >> Technical Support >> Copy identical millwork elevations
Mon, Jan 26, 2015 at 10:25:51 AM | Copy identical millwork elevations
aharris509
We do a lot of Medical Office Buildings and this has happened more than once here. We will have a nurse station that is pretty much indentical to one that we did on another job, it would be nice if there were a way to copy not only the model geometry (cabinets/counters etc..) but also be able to copy in the completed (dimensioned & annotated) millwork elevation. We really cant find a way to do this easily....what we do now is copy/paste the modeled elements, then create an elevation, then copy/paste the annotation if possible, then we need to re-dimension it. Has anyone run into this similar situation, and if so do you happen to have a better work flow?
Thank You,
Alan
Mon, Jan 26, 2015 at 10:31:26 AM | Copy identical millwork elevations
In the original model, you can group the model elements along with all of the 2D elements that you want to copy.   (NOTE : Any dimensions to walls, floors, levels and grids that will not be copied will not work.)  Now - export the group or just copy/paste into your new model.   I then suggest you ungroup it and delete the group from your new model.
Problems with linked files and interior elevations
Wed, Aug 3, 2011 at 7:59:52 AM
MILLWORK MANUFATURERS? anyone use revit for that?
Mon, Mar 2, 2009 at 6:03:23 PM
Group instances of the same type do not contain identical members
Sat, Jan 23, 2016 at 7:57:37 PM
Need advice on elevations and plans.
Tue, Mar 6, 2007 at 6:04:47 PM
millwork families to have hatch in plan view only
Tue, Jan 26, 2016 at 9:54:59 AM
Page generation time: 0.1993
