Forums >> General Discussion >> Revit Project Management >> Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:41 AM | Fireplace doesn't export out into STL file
tfcrec
I downloaded a several fire places from Revitcity and I 'm having problems with them not exporting out into a STL file so the client can use to print a 3d model. The client is saying there is a hole in the modle where the fireplace is suppose to be. I've used several diffrent fireplaces and the samething happens. I was told export as an fbx file and then bring into blender and export it into a STL file which seems to work fine eexcept for this fireplace problem. Is there something i must do to the fireplace before I export it to an fbx file? Thanks
.stl file creation?
Thu, May 17, 2007 at 12:50:53 PM
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:05 PM
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:31 AM
Exporting Topo to STL as a solid for 3D Printing
Fri, Feb 9, 2018 at 4:51:21 AM
STL export tips
Mon, Nov 22, 2010 at 10:33:33 AM
Page generation time: 2.1443
