Forums >> General Discussion >> Revit Project Management >> Ground Level 0'-0" has changed!!!
Thu, Jan 22, 2015 at 5:46:27 PM | Ground Level 0'-0" has changed!!!
jwilliamson
So we are 75% through the project and the civil engineer has changed the 0'-0" of the project up 1'-0". How can I change the upper levels to read 1' less? Example is my ground level is 0'-0" and my first floor is 12'-0". Now that civil has moved the grade up 1' my first floor will need to be 11'-0". Selecting and changing the level value gives me warnings that different objects will be deleted and my choices are OK delete these objects or CANCEL (sweeps, dimensions, hosted elements). How do I change the levels without having everything deleted?
Thu, Jan 22, 2015 at 6:21:42 PM | Ground Level 0'-0" has changed!!!
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In elevation view (or section), select any level and in type properties make sure ‘elevation base’ is set to ‘survey point’. Go to manage tab (ribbon) -> position (project location panel) -> relocate project and move 1’ down. You might need to adjust your ground level elevation – just move it up 1’ to make it show desired value.
Fri, Jan 23, 2015 at 7:09:58 AM | Ground Level 0'-0" has changed!!!
jwilliamson
Again any time I move/change the elevation of a level ground or otherwise I get the warning message saying things will be deleted. Is there a way to move the levels without causing warnings.
Fri, Jan 23, 2015 at 10:35:19 AM | Ground Level 0'-0" has changed!!!
Watch this video:
http://www.youtube.com/watch?v=BigvY4LT-RI
Move objects with level change
Mon, Sep 12, 2005 at 10:11:16 PM
Toposurface
Fri, Nov 20, 2015 at 11:56:27 AM
Change 0'-0" MAIN LEVEL to 100'-0"
Tue, Aug 22, 2006 at 7:40:49 PM
Trying to move entire model to a different level!!
Thu, Jan 28, 2010 at 2:18:31 PM
Shade view of toposurface
Fri, May 19, 2006 at 9:35:11 AM
Page generation time: 0.7638
