Forums >> Revit Building >> Technical Support >> 3d Visibility
Tue, Mar 14, 2006 at 11:32:05 PM | 3d Visibility
whoopsyvroom
Is there any way to show the interior of each of 4 levels of a building on separate sheets in 3d format. I have tried cropping without success
Wed, Mar 15, 2006 at 12:52:58 AM | RE: 3d Visibility
eldados
eldados Avatar
4.5 Stars: 8 Votes
oh but off course... you can either orient your 3D to a section going through your space, rotate to desired position and save view as a different name. rinse and repaet for all your views... HTH
Integrator
KarelCAD
Wed, Mar 15, 2006 at 10:50:39 AM | RE: 3d Visibility
gautamrs
gautamrs Avatar
5 Stars: 3 Votes
have you tried working with the section box? Under view properties, you'll find the check box for this command in the extents field.... hope this helps...
Wed, Mar 15, 2006 at 11:54:57 PM | RE: 3d Visibility
whoopsyvroom
Thanks for the help. I have been busy with other work but will be trying the solutions offered. Thanks again.
Sun, Mar 19, 2006 at 12:41:08 AM | RE: 3d Visibility
whoopsyvroom
It worked. Many thanks
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY
Mon, Aug 7, 2006 at 5:36:38 PM
Symbolic Element Visibility
Tue, Feb 4, 2020 at 6:42:28 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:39 AM
Page generation time: 2.4460
