Forums >> Revit Systems >> Technical Support >> Project Browser
Sat, Jan 17, 2015 at 3:49:06 PM | Project Browser
KimCadMan
I am testing some filters in Project Browser.  I created a "Sheet Phase" parameter, Text, Identity Data, instance, "Sheet" category.
Some Sheets I assigned "Phase I" to the sheet phase, and others I assigned "Phase II" (mind you without the quotes).  I wanted to apply a filter, under filter by of the Filtering Tab, I selected "Sheet Phase", equal to "Phase I".  I then went to the next section "And" selected the same sheet phase and equal to "Phase II".  Essentially I'm wanting both Phase I and Phase II as the filters.  Is this not possible?  Once I click ok and apply no sheets are listed under my Sheets.  Why is that, any info would be greatly appreciated.
Mon, Jan 19, 2015 at 7:54:23 AM | Project Browser
Filters are single limiting.   Your first limit is "Phase I' so no 'Phase II' will be included.  If your filter is set to begins with 'Phase I', you will get bothe 'Phase I' and 'Phase II'.
Plan in Project Browser
Fri, Oct 10, 2014 at 9:15:22 AM
Project Browser Missing!!!
Thu, Oct 4, 2012 at 3:47:37 PM
Project Browser Location
Tue, Sep 29, 2009 at 12:35:32 PM
project browser
Sat, Jun 23, 2012 at 8:56:37 AM
Project Browser
Tue, Apr 1, 2008 at 8:00:32 AM
Page generation time: 1.7521
