Forums >> Revit Building >> Technical Support >> MARKETING DIMENSIONS
Thu, Jan 15, 2015 at 6:27:18 AM | MARKETING DIMENSIONS
online2000
online2000 Avatar
hi all
here is another challenge-
1/we need to reduce room dimenions on the marketing plans so that we cover our behinds when it comes to inaccuracies when the building is handed over to buyers- this is usually done in Autocad with a -5 alteration to all room dimensions, however we can't do this with REVIT in the case of chaging dimenion's text.
any ideas?
i thought of adding a 2,5cm plaster layer to walls and dimensions this- howevr this doesnt always work out to favour the idea in concept!!!
basically: is there a way of creating a formula that will redice the indiacted dimenions?
2/ is there a way to have automatic length and width of rooms tag???
glad to challenge you all...
E
eli
Thu, Jan 15, 2015 at 7:03:53 AM | MARKETING DIMENSIONS
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The dimensions in Revit are what you drew them as, there is not formula or faking it.  I don't understand your second question on automatic length and width of room tags
Thu, Jan 15, 2015 at 7:30:41 AM | MARKETING DIMENSIONS
You can add a very small line inside your wall and dimension to that.
We have multiple room tag types that have different text size/width for use in smaller spaces.
Thu, Jan 15, 2015 at 8:00:07 AM | MARKETING DIMENSIONS
online2000
online2000 Avatar
the idea is to avoid having to add the extra line- or extra plaster thickness so that it doesn't show up on marketing plans. the 5cm reduced dimension is used in our market to avoid handing over a unit that is too smal - this was we already have a tolernce that reduced our planning by a fiuxed dimension,
for example, a 4X3 room may indate rather 2.95X3.95 on contract drawings and thus, we give ourselves a tolerance in case that built size diviates from orinial plans
my only method was to add the additional plaster thickness, and make it whie in cut lines, but was causeing problems later
eli
Thu, Jan 15, 2015 at 8:05:08 AM | MARKETING DIMENSIONS
I would think that a note giving acceptable tolerances is a far better solution to an inaccurate dimension.
Wed, Mar 25, 2026 at 1:23:11 PM | MARKETING DIMENSIONS
wuvgy
1 Stars: 1 Votes
Working with REVIT for marketing plans can definitely be tricky, especially when you’re trying to adjust room dimensions for presentation purposes without affecting the actual building model. Unlike AutoCAD, where you can simply apply a uniform adjustment to all dimensions, REVIT ties dimensions to the model elements themselves, so changing text or displayed measurements requires more creative solutions. Adding a plaster layer or offsetting walls can sometimes help, but as you noticed, it doesn’t always give the intended result conceptually. One approach is to explore calculated parameters or formulas within REVIT schedules, which can create display dimensions that automatically adjust based on your chosen offset, so the model stays accurate while the marketing plan shows the intended reduced sizes. Similarly, using room tags with calculated values can let you automatically display adjusted lengths and widths without manual edits, saving time and reducing errors. For professionals juggling these kinds of technical challenges and looking for resources, directories like AFFCatalog can sometimes highlight case studies or tools used in architecture and marketing campaigns, providing practical examples for applying these techniques efficiently.
New Autodesk marketing video
Thu, Mar 18, 2004 at 5:22:59 PM
Marketing
Tue, Oct 10, 2006 at 7:01:27 AM
Manufacturer's Revit Models are for marketing only? Do you agree with this?
Mon, Oct 11, 2010 at 9:03:28 PM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Page generation time: 0.6917
