15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Level does not show in plan view
1 Posts No Rating |
Using Revit 2015 I have created a basement with a level line (that is blue) through it. The level shows up in the browser under plan views but when I click on it I see nothing. View range seems fine...what is going on???
Many possibilities.
- The view range is wrong
- No model elements cut
- The view is cropped away from the model
- Nothing is on in VG
- Using phases and view is set wrong
- Using design options and view is set wrong
- .... and more
This is a process problem but you don't give us enough information to help.
1 Posts No Rating |
Well, I changed the phase to Project Completed and it showed up...but I don't really know why. At least I can see something.
Good opportunity to learn. Search PHASES in your HELP and start reading.
Walls show up on Second Level plan |
Wed, Dec 19, 2018 at 8:39:24 AM
Walls do not show up in plan view |
Tue, Mar 10, 2009 at 1:49:55 PM
Floor Plan associated to wrong level... |
Fri, Jul 2, 2021 at 3:23:05 PM
Plan view levels |
Tue, May 5, 2009 at 3:15:03 PM
Revit component wont show up in plan view |
Thu, Mar 15, 2012 at 2:55:51 PM
