10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> How would you proceed
0 Posts No Rating |
Not sure if I'm posting this in the correct place.
I'm trying to figure out the best way to proceed. I have built my model in Revit 2015 and after a cost estimate coming in over budget there are now changes that need to be made. Initial model has masonry exterior walls, a combination of brick and CMU. The change is one elevation will now be stucco as the base bid and the masonry will be an alternate. This means I will to have two elevations on my drawings, one showing the stucco and one showing the alternate with masonry.
So my question is how is the best way to go about this? Is there a good way to model this or should I just model one and use lines to draw the other one?
Thanks for any input.
Check out Design Options.
Transition from AutoCad to Revit - Looking for info, ideas for how to proceed |
Mon, Dec 26, 2011 at 9:46:00 AM
Phasing / Floor Infill |
Tue, Mar 6, 2012 at 11:15:01 AM
How do you chamfer two different wall types? |
Tue, Jun 28, 2011 at 10:38:16 AM
Overall Plans and Partial Plans ... looking for Best Practice |
Mon, Nov 8, 2010 at 10:30:16 AM
Reviosion Cloud Editing? |
Fri, Mar 30, 2007 at 11:15:50 AM
