Forums >> Revit Building >> Technical Support >> The special problem!! in mass surface divide.
Thu, Jan 8, 2015 at 11:30:51 PM | The special problem!! in mass surface divide.
xkaqnr3
I want to expressive the Grid of object, But the object have a big difficult surface to me..
So I want to solve the problem together!
Maybe I was tried 6 times, but I couldn't make the object perfectly....
The object seems like Baguette! but not normal baguette, there are so many grid line in surface.
(Refer the attach the image file "13")
I will Explaining the process of creating an object... Until now
1. Setting the drawings in revit
2. Sketch the Border Line to use the pick line
3. Select all line and create the solid form
4. Sketch the grid line of the drawing to use the pick line
5. Divide surface of the form and select unclick of the U.V grid
6. Intersects "the drawing line" with "surface"
then, you can check the situation of attch file" 11"
It looks like well done, but the problem is when I apply the family in surface, It will create, by grid(intersect)
line and  surface outline. like attach file "12"
I don't want to expressive the outline in applying of family.
what should I do?..If you have a Good Idea! or other way! Please help me~!
Divide Surface of conceptuall mass by level?
Wed, Jan 13, 2010 at 5:23:14 AM
Created forms and divide surface tools
Wed, Jan 1, 2014 at 4:34:46 AM
Creating irregular patterns with divide surface
Fri, Sep 28, 2012 at 10:00:35 AM
Adding Material to Divided Surface
Thu, Apr 17, 2014 at 10:40:12 AM
dividing faces
Thu, Jul 14, 2011 at 3:37:27 PM
Page generation time: 0.6811
