23 Users Online (21 Members):
Forums >> Community >> The Studio >> LEADERS AND ARROW HEADS
3 Posts No Rating |
I NEED TO MAKE A LEADER W/ NO TEXT, ALSO I NEED TO HAVE ARROW HEADS AT EACH END OF THE LEADER. ANY IDEAS?
THANKS
You could do this as a temporary work around:
1. Select the dimensions tool and goto its properties.
2. Click on Edit/New.
3. Click on Duplicate to create a new Dimension Type.
4. Give the dimension type a new name like... Arrows only
5. Now Change the text size to 1/256" (smallest you can get)
6. Change Units Format to Decimal Feet, rounding to 0 decimal places, and choose a font that is very thin like TXT or Proxy 1. You now have a font that is so thin and small it won't register.
7. Change Dimension Line Extension, Witness Line Extension, and Text Offset to 0”
8. Change the Tick Mark to Arrow Filled
Now as long you have two objects to dimension between, you will get a line with an arrow on each end
best regards,
coreed,AIA
Just create as a detail component or generic annotation family
Revit Structure wishlist items |
Tue, Apr 14, 2009 at 4:52:47 PM
Different leader heads at the same time? |
Fri, Jul 12, 2013 at 12:06:29 PM
Leaders |
Wed, Apr 21, 2010 at 11:59:44 AM
Leaders moving_Annoying |
Fri, Jan 20, 2012 at 7:37:30 AM
Section heads - (Revit 2010) |
Mon, Nov 16, 2009 at 12:48:38 PM
