Forums >> Revit Structure >> Technical Support >> Can't miter a column to a beam?
Wed, Jan 7, 2015 at 4:15:13 PM | Can't miter a column to a beam?
YoungProfesional
i'm working for a structural steel fabrication shop and i'm trying to convert to Revit, re-taking a class soon -its been a few years.  i can do it in CAD in my sleep.
i have a steel frame made of 3 -W4x13 beams, 2 upright columns & 1 horiz. beam and the client wants to miter cut them all and weld but i can't get Revit to do it, please help.
Wed, Jan 7, 2015 at 8:20:38 PM | Can't miter a column to a beam?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Select a beam, right click on the blue dot and pick ‘edit beam/column join’ and click on the blue arrow. I’m not sure if that’s what you’re asking for though, some screen shots of what you're after would be helpful.
column-beam connection
Tue, Jan 12, 2010 at 5:46:46 AM
LENGTH OF TEXT IN 'TYPE' IN BEAM SCHEDULE
Sat, Nov 6, 2010 at 8:37:23 AM
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
Tee beam as column?
Tue, Nov 6, 2012 at 2:41:46 PM
Page generation time: 0.5492
