Forums >> Revit Structure >> Technical Support >> Can't dimension to center of a circle? NewtoRevit
Wed, Jan 7, 2015 at 4:11:00 PM | Can't dimension to center of a circle? NewtoRevit
YoungProfesional
i'm creating a family for a base plate with 4 bolt holes but i can't dimension the center of the bolt holes?
Thu, Jan 8, 2015 at 6:43:27 AM | Can't dimension to center of a circle? NewtoRevit
It would be better to have located the holes by using reference planes and dimentioning to those.
Thu, Jan 8, 2015 at 7:59:17 AM | Can't dimension to center of a circle? NewtoRevit
My previous answer was based on dimentioning in the family.  If you want to dimension in the project, you will have to make those reference lines "stron reference".
BTW _ for annotative circles, you can turn on the center under properties.
Thu, Jan 8, 2015 at 9:10:30 AM | Can't dimension to center of a circle? NewtoRevit
YoungProfesional
thank you that really helps!
Constraining a circle centered between two reference planes
Fri, Apr 7, 2017 at 8:22:50 AM
Dimension for curve line
Wed, Mar 21, 2007 at 7:11:01 AM
Dimension center line of foundation
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
orthogonal dimensions to radial dimension center point
Fri, May 14, 2010 at 3:22:32 PM
Page generation time: 1.4989
