Forums >> Revit Building >> Technical Support >> Designing a fitness center
Wed, Jan 7, 2015 at 9:44:32 AM | Designing a fitness center
nicolehag
I am kind of new to Revit but I am learning lots and learning fast. For work I am suppose to design a new training center for the recruits. Is there a way to make a rope climbing wall like in the picture I have posted?
Wed, Jan 7, 2015 at 11:02:16 AM | Designing a fitness center
You might be able to model it but that may be ebyond where you are.   Is there something like this in google warehouse?  If so, you can import that.
Wed, Jan 7, 2015 at 11:12:35 AM | Designing a fitness center
nicolehag
Im not sure what Google warehouse is but I googled it to see if I could find anything and I did not. I didnt find anything like it on Revitcity either. I did find one that I liked on another website but you have to pay $200 to sign up for the website, which I was trying to avoid.
Wed, Jan 7, 2015 at 11:20:07 AM | Designing a fitness center
You needed to look a little better.  Here is one and there may be others.
https://3dwarehouse.sketchup.com/model.html?id=41fdc4107394d1e0b110b334c9f3e39
Wed, Jan 7, 2015 at 11:31:28 AM | Designing a fitness center
nicolehag
Thats not really what I am looking for though. I dont want a playground, just the rope ladder.
Wed, Jan 7, 2015 at 11:35:09 AM | Designing a fitness center
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can do this using sweeps if you need to have a little "bend" to it or if just straight up and down you can do it using extrusions.
Wed, Jan 7, 2015 at 2:00:51 PM | Designing a fitness center
Didn't you see the rope ladder in the playground?   Do you know how to delete what you don't want?   Pretty easy process.
Wed, Jan 7, 2015 at 2:06:48 PM | Designing a fitness center
nicolehag
Sorry I didnt know you could do that.
Wed, Jan 7, 2015 at 2:08:19 PM | Designing a fitness center
You have to edit it in sketchup.... save - then import into Revit.
Wed, Jan 7, 2015 at 2:31:16 PM | Designing a fitness center
nicolehag
oh okay sounds easy enough! Thanks!
Center to center as default for importing
Fri, Feb 19, 2010 at 11:01:45 AM
inserting Center to Center
Tue, Apr 2, 2013 at 11:01:10 AM
Outlet Visibility Above Cut Plane
Wed, Nov 5, 2014 at 11:03:01 AM
Problem when designing a family
Fri, Feb 10, 2017 at 12:42:44 PM
Designing irregular stairs
Tue, Jan 10, 2012 at 12:57:33 PM
Page generation time: 0.0998
