15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> revit zoom factor
How can I know the drawings showing on the computer screen are same as the printed? I guess there is a zoom factor which has a relationship with the scale of the drawing.
My way is drawing a region and make sure the models fill in. Any other ways?
If you set the scale in the view, place the view on a sheet then print scale 100%, then the item will be printed correctly according to the view scale.
Thanks.
When I scroll the mouse middle button, zoom in/out, when the items show as same as the view scale.
I try to do like this
I don't know what you are showing us with that image.
Revit does not run like CAD. I think you need to spend some time with the tutorials. The zoom on the screen has nothing to do with the printed output. It is on your screen.
Zoom and text - any way to tell which zoom level you are working in? |
Wed, Jan 7, 2015 at 9:30:59 AM
Text Box Width Factor Masking Error |
Wed, Mar 18, 2015 at 2:33:50 PM
occupant load factor |
Fri, Oct 14, 2011 at 10:31:08 AM
Width factor as a parameter |
Thu, Oct 30, 2014 at 7:23:29 AM
Hatch Pattern Scale Factor |
Tue, Jun 17, 2008 at 12:36:29 PM
