Forums >> Revit Building >> Technical Support >> Joining different Cavity walls
Mon, Jan 5, 2015 at 9:39:23 AM | Joining different Cavity walls
geraldrogers
Is there a way of overiding which internal wall of two different cavity walls takes preference? I have a block / brickwork cavity wall and a rc wall / brickwork cavity wall. I want the rc wall to extend where they meet at a corner but it seems the block version wants to take priority. See attached image.
Gerald Rogers
Revit 2015
Mon, Jan 5, 2015 at 10:27:47 AM | Joining different Cavity walls
geraldrogers
Just found out how to achieve this! By changing the function of the inner block wall from structure [1] to substrate [2] in the assembly edit.
Gerald Rogers
Revit 2015
Mon, Jan 5, 2015 at 12:26:43 PM | Joining different Cavity walls
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Here are some join rules and priorities for wall layers.
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:38 AM
Cavity walls
Tue, Jul 5, 2011 at 7:07:42 AM
Cavity Wall Around Bay Not Showing Correct Detail
Sun, Jan 17, 2010 at 3:50:13 PM
Cavity wall for Revit 2008
Thu, May 26, 2011 at 12:06:42 PM
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Page generation time: 2.6669
