Forums >> Revit Building >> Technical Support >> Railing Issue again- hopefully with attachments this time
Sun, Jan 4, 2015 at 11:17:18 AM | Railing Issue again- hopefully with attachments this time
5dtgeorgiton4
I can't figure out how to trim a section of railing that is blocking my
2nd run of the stairs. The first time I tried to attach the revit file but it didn't work- have attached both the revit file
and a .pdf this time- I hope it works. I am using student version of revit- is that why the revit file didn't come through?
Thanks ahead of time for any help with this.
Mon, Jan 5, 2015 at 7:54:00 AM | Railing Issue again- hopefully with attachments this time
The revit file did not attach - probably because you did not pay any attention to the file upload limits.
Mon, Jan 5, 2015 at 1:48:12 PM | Railing Issue again- hopefully with attachments this time
5dtgeorgiton4
Hi-
  The Revit File size is 3,336 KB - I think it is because I have the student version of Revit that I can't upload the actual Revit file.
Mon, Jan 5, 2015 at 3:01:13 PM | Railing Issue again- hopefully with attachments this time
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You don't trim it, edit the railing path and delete the line that is going infront of your stair.
Railing issue
Wed, Jun 13, 2018 at 2:15:01 AM
rectangular railing
Mon, Nov 26, 2012 at 7:30:07 AM
L shape wall without removing top and base attachments
Tue, Jun 3, 2014 at 7:33:43 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
stair railing transition at landing issue (2015)
Wed, Sep 16, 2015 at 9:29:50 AM
Page generation time: 1.8071
