Forums >> General Discussion >> Wishlist >> Revit View Range Interface Improvement - Vote on 3 ideas, then add your own
Sun, Dec 28, 2014 at 11:53:39 AM | Revit View Range Interface Improvement - Vote on 3 ideas, then add your own
ECOMAN
I think the View Range Interface need improvement. There are several good visual references, but it is still not intuitive enough or user-friendly enough.
I will start "#" numbering 'problems' with "Fix:" improvements that Austodesk could make. Please 'vote', comment/critique, or offer new suggestions in the same "#" + "Fix:" approach.  I will try to add them to a running list. I'll also post this on several forums with the hope to have some small impact on the Autodesk Revit development team.  Clear as concrete? Ok, here we go...
REVIT VIEW RANGE INTERFACE IMPROVEMENT
#1: In the Revit View Range Dialogue Box, why is "Associated Level" spelled out? Since the box size is fixed (see #2) 16 characters is way too many.
#1 Fix: Shorten it to "Level" (6 characters) since it is implied that it is an association.  Only if Autodesk thinks 'Associated' need to be clearly defined, it should be abbreviate it to "Assoc.Lvl.", or "Assoc.Level"
#2: Why is the Revit View Range Dialogue Box size locked?
#2 Fix: Unlock the Revit View Range Dialogue Box grab and size capability
#3: Why isn't a visual aide included to the left of the Revit View Range Dialogue Box?
#3 Fix: Add a graphic or a miniature elevation clip to the left side of the box, like there is for a Wall Preview.
That's my 3, please vote or comment, and/or and let me know if you have any more to add.
Tue, Dec 30, 2014 at 5:17:13 AM | Revit View Range Interface Improvement - Vote on 3 ideas, then add your own
gebber
gebber Avatar
5 Stars: 4 Votes
I don't see the need for your first 2 ideas but totaly agree on your third idea.
It would help a lot if there was a miniature elevation clip as we know from autocad.
Tue, Dec 30, 2014 at 12:19:11 PM | Revit View Range Interface Improvement - Vote on 3 ideas, then add your own
fastjohnnyz
I definitely like option 3.
Tue, Dec 30, 2014 at 2:10:44 PM | Revit View Range Interface Improvement - Vote on 3 ideas, then add your own
You need more than an image.  This document really helps:
http://therevitkid.blogspot.com/2011/07/revit-tip-floor-plan-and-ceiling-plan.html
Revit MEP 2012-View Range
Fri, Apr 12, 2013 at 7:22:48 AM
Plan cuts incorrectly at windows despite correct view range
Thu, Aug 6, 2009 at 9:12:23 PM
View range problem
Fri, Apr 1, 2011 at 12:47:39 PM
component above view range not showing up in plan
Thu, Oct 30, 2008 at 4:27:11 PM
View Range does not show Existing / Demolition / New correctly
Wed, Oct 27, 2010 at 1:46:40 PM
Page generation time: 2.1103
