Forums >> Revit Structure >> Technical Support >> Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 3:00:40 PM | Inner walls overlapping outer walls.
MariusCosmin
Hi,
I can't figure out why the inner walls of the house keep overlaping the outer walls.
Any help is welcomed.
Edited on: Sun, Dec 14, 2014 at 3:04:44 PM
Sun, Dec 14, 2014 at 3:47:08 PM | Inner walls overslaping outer walls.
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
The core layer will join with the core layer of the second wall. See this and this for more info.
Sun, Dec 14, 2014 at 4:58:35 PM | Inner walls overslaping outer walls.
MariusCosmin
The second link did the trick. Thank you Smile
intersecting inner walls with slanting outer walls
Wed, Feb 27, 2013 at 7:51:10 AM
Building 20+ story skyscraper/highrise how do make outer structure?
Mon, Mar 28, 2011 at 10:27:03 PM
Join walls command for a group. Issue
Sun, May 13, 2018 at 11:06:02 PM
walls on different levels not even
Tue, Sep 9, 2008 at 2:14:45 AM
Join 2 roofs, like joining 2 walls
Wed, Nov 10, 2010 at 7:23:34 AM
Page generation time: 2.6680
