Forums >> Revit Structure >> Technical Support >> Raft Foundation inconstant slab thickness
Sat, Dec 13, 2014 at 2:49:15 PM | Raft Foundation inconstant slab thickness
azsaqib
Dear Experts,I have modeled raft foundation slab which has slop as shown in linked file & I have all slab thickness 300mm but its does not show same. what could be the problem or any alternative way to do that. Thanks.
Wed, Dec 17, 2014 at 9:43:55 AM | Raft Foundation inconstant slab thickness
I will not open your file because you did not say what Revit.
I suggest you post images of how you did your slab instead and the properties.   Did you do a slope arrow or what?
Wed, Dec 17, 2014 at 3:01:20 PM | Raft Foundation inconstant slab thickness
azsaqib
Thanks WWHub its Revit 2014 file.
Here is the imege file. I used the Structural foundation salb. Because i need this at Foundation Level. From Floor Structural Slab i make this 100% right. But i need from structural foundation slab not Structural Floor.
Thanks.
Wed, Dec 17, 2014 at 3:25:53 PM | Raft Foundation inconstant slab thickness
Not sure what you mean by this: "... I used the Structural foundation salb. Because i need this at Foundation Level...."   You can use a slab at any level.
Are you just concerned about what category this is in?
Wed, Dec 17, 2014 at 3:45:25 PM | Raft Foundation inconstant slab thickness
azsaqib
I have modeled raft foundation slab which has slop as shown in linked file & I have all slab thickness 300mm but its does not show same. what could be the problem?
Thu, Dec 18, 2014 at 8:00:55 AM | Raft Foundation inconstant slab thickness
I think we have a language problem here.
Your question is not at all clear.  You need to mark up your image with what you want .   Just add some lines and text in paint.  The slab appears to be the same thickness.   The red circle doesn't tell us anything and you did not say how you created this item.
Read these sections in your HELP:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-8E202020-8845-47F8-A686-8688A569938A
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-296F9E46-85F9-4E15-9EF2-39411FA44CA3
Thu, Dec 18, 2014 at 2:21:07 PM | Raft Foundation inconstant slab thickness
azsaqib
Dear WWHub,
My question is that i make the raft with the help of Structural Foundation slab. when i complete this i need to draw some slop area as you see in the picture. i used the Slop Arrow function to draw the slope, which you see in the picture. The problem is that when i draw the slope slab its thickness is not same as straight slab. but i use the same slab thickness for both straigh and sloped slab.
Shap edit tool work with Structural slab. its not work with foundation slab. just i need to know where i am wrong.
Thanks hope this time you understand the question.
Thu, Dec 18, 2014 at 2:36:04 PM | Raft Foundation inconstant slab thickness
The slab is correct as you have modeled it.   It is all 300 thick.   Your problem is you want it to be 300 vertical rather than thickness and that is not how Revit works. Slab thickness has always been calculated as perpindicular to the surface - not the world.   Calculate a different thickness based on what you want and create a new slab type with that.   It looks like it needs to be 287.
If you want to have the correct thickness at 300, then you will have to have a slab edge around your flat slab that creates the transition.
Tue, Dec 23, 2014 at 4:50:01 AM | Raft Foundation inconstant slab thickness
imrankhan
WWHub, if we make slab thickness 287 it will effect the quantity schedule...any alternative solution as it may occure anywhere where to elements join in slope.
Tue, Dec 23, 2014 at 7:40:29 AM | Raft Foundation inconstant slab thickness
I probably would not worry about this since it is not visual.  Your quantity take-off will basically be correct and you can use edit cut profile in any sections that show this blend as missing.  As I stated previously: "...If you want to have the correct thickness at 300, then you will have to have a slab edge around your flat slab that creates the transition...."
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
path or area reinforcement in raft foundation
Sun, Aug 29, 2010 at 1:16:18 AM
Raft Foundation Sweeps
Wed, Feb 13, 2008 at 8:10:08 AM
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Page generation time: 1.3347
