Forums >> Revit Building >> Technical Support >> Mirror issues, mouse selection issues
Wed, Dec 10, 2014 at 3:24:24 PM | Mirror issues, mouse selection issues
sroreilly
Using Revit 2014.
For two days I have been having two issues.
1. When I attempt to mirror projects, I get the error message: "Analytical model edge cannot have a length of zero". To get yesterday's project drawing to mirror, I deleted all the foundation walls & slabs, & kept trying until it worked.
2. On floor plan views, I cannot select anything with my mouse. (It started with not being able to drag stuff, now I can't select things in plan view.. )
I didn't change anything in setting up my projects (these are plans I've used before with no issues). I have not changed my options in Revit, nor any mouse settings.
I'm ready to throw the tower across the room...... Any suggestions? I'll go eat some more chocolate while I hope someone has a suggestion!
Thanks,
Susan.
Wed, Dec 10, 2014 at 4:05:24 PM | Mirror issues, mouse selection issues
Start by installing all updates - 2 I believe.
Close the project and re-open with an audit.
Tell us more:
  • worksets
  • phases
  • links
  • are you using 'mirror project' tool or just the mirror command?
  • Are you in structure?
Wed, Dec 10, 2014 at 4:14:28 PM | Mirror issues, mouse selection issues
sroreilly
Thanks.....
here's an update: I seem to have better luck mirroring when I remove all structural beams.... Never had to do that before.
- no special worksets used
-no phases (these are small projects, just me using the program..... (lonely world, here!))
-no links
-I'm using the mirror project tool, under Position in the Project Location tab
-I'm not in Structure, but I believe it has to do with structural beams. Though, this is a new issue.
-all updates are installed.
-I've rebooted my computer.... never opened with an audit before...... hmmmmm.
(Chocolate worked... I'm calmer ;-) )
Zoom Issues
Sat, Dec 1, 2012 at 4:32:57 AM
Logitech MX-1000 Mouse issues
Tue, Oct 11, 2005 at 10:56:31 AM
Mirror reflection always looks too distorted in renderings
Tue, Jan 27, 2009 at 4:15:43 PM
ISSUES
Sat, Oct 15, 2016 at 3:18:38 AM
RAC 2012 Highlight / Select issues
Wed, Jul 27, 2011 at 5:47:35 PM
Page generation time: 0.7307
